You can use ReadyFlows as the starting point of your flow design. Select an available
ReadyFlow from the ReadyFlow Gallery, open it for editing on the Canvas, and publish it to
the Catalog as your own custom flow definition.
You have an enabled and healthy Cloudera Data Flow environment.
You have been assigned the DFDeveloper role granting you access to
the Flow Designer.
You have been assigned the DFCatalogAdmin or DFCatalogViewer role
granting you access to the Catalog. You will need this authorization to
publish your draft as a flow definition to the Catalog.
You have been assigned the DFFlowAdmin role for the environment to
which you want to deploy the flow definition.
ReadyFlows are read-only, therefore you cannot add a new
version to them. When you are done with creating your customized version of the given
ReadyFlow, you can only publish your work to the Catalog as a new
flow definition.
Open Cloudera Data Flow by selecting the
DataFlow tile in the Cloudera on cloud sidebar.
Select
ReadyFlow Gallery in the left
navigation pane.
Select the ReadyFlow you want to use as a template for your flow design.
Click Create New Draft.
Select the Target Workspace where you want to create the
draft.
Select the Target Project to which you want to assign
the draft.
Provide a valid Draft Name for the draft.
Flow names must be unique within a workspace. If a draft with the provided
name already exists, you need to provide a different name.
Click Create.
The selected ReadyFlow opens as a draft in the designated Flow Designer
workspace with the Draft Name you provided, on the
Flow Design canvas.
