Deleting a flow definition
You can delete a flow definition along with all its versions from the Cloudera Data Flow UI.
You have imported at least one flow definition.
  1. In the Cloudera Data Flow UI, from the left navigation pane, click Catalog.
    Flow definitions available for you are displayed, one definition per row.
  2. Identify the flow definition you wish to delete, and click the row to display the flow definition details and versions.
  3. From the Actions drop-down, select Delete Flow Definition.
  4. Enter the flow definition name, and click Delete.
