Running Commands in impala-shell
For information on available commands, see impala-shell Command Reference. You can see the full set of available commands by pressing TAB twice:
[impalad-host:21000] > connect describe explain help history insert quit refresh select set shell show use version [impalad-host:21000] >
For example:
[impalad-host:21000] > select * from alltypessmall limit 5 Query: select * from alltypessmall limit 5 Query finished, fetching results ... 2009 3 50 true 0 0 0 0 0 0 03/01/09 0 2009-03-01 00:00:00 2009 3 51 false 1 1 1 10 1.100000023841858 10.1 03/01/09 1 2009-03-01 00:01:00 2009 3 52 true 2 2 2 20 2.200000047683716 20.2 03/01/09 2 2009-03-01 00:02:00.100000000 2009 3 53 false 3 3 3 30 3.299999952316284 30.3 03/01/09 3 2009-03-01 00:03:00.300000000 2009 3 54 true 4 4 4 40 4.400000095367432 40.4 03/01/09 4 2009-03-01 00:04:00.600000000 Returned 5 row(s) in 0.10s [impalad-host:21000] >
Page generated September 3, 2015.
<< Connecting to impalad through impala-shell | impala-shell Command Reference >> | |
