Cloudera Documentation
Managing ProjectsPDF version
Linking an Existing Project to a Git Remote
If you did not create your project from a Git repository, you can link an existing project to a Git remote (for example, git@github.com:username/repo.git) so that you can push and pull your code.
  1. Launch a new session.
  2. Open a terminal.
  3. Enter the following commands:
    Shell
    git init
    git add *
    git commit -a -m 'Initial commit'
    git remote add origin git@github.com:username/repo.git
    You can run git status after git init to make sure your .gitignore includes a folder for libraries and other non-code artifacts.
