Modifying Project settings
Project contributors and administrators can modify aspects of the project environment such as the ML Runtimes used to launch sessions, the environment variables, or can create SSH tunnels to access external resources.
  1. Switch to the account where the project was created.
  2. Click Projects.
  3. From the list of projects, select the one to modify.
  4. Click Project Settings to open the Project Settings dashboard.
    You can see the following configuration tab options in the Project Settings dashboard:
    General
    Modify the project name, description, visibility (privacy settings), and owner on this page. For the Project Owner, only individual users (not Teams) can be assigned, and only an Administrator can change the owner.
    ML Runtimes
    You can add, remove and configure the ML Runtimes on this tab. When starting a Cloudera AI session, job, application, or model the ML Runtime variant to be used can be chosen from this list.Cloudera AI ensures that your code is always run with the specific ML Runtime version you selected.
    Advanced
    • Environment Variables - If there are any environmental variables that have to be injected into all the ML Runtimes running this project, you can add them to this page. For more details, see ML Runtimes Environment Variables.
    • Ephemeral Storage Settings - Ephemeral storage space is a scratch space that a Cloudera AI session, job, application or model can use. For more information, see Ephemeral storage.
    • Shared Memory Limit - You can specify additional shared memory available to sessions running with the project.
    SSH Tunnels
    In some environments, external databases and data sources reside behind restrictive firewalls. Cloudera AI provides a convenient way to connect to such resources using your SSH key. For instructions, see SSH Keys.
    Data Connections
    Data Connections connect projects to data sources. For more information, see Data connection management.
    Delete Project
    This page can only be accessed by Project Administrators. Remember that deleting a project is irreversible. All files, data, sessions, and jobs are removed.
