Uploading Model Repositories for an air-gapped environment
The Model artifacts must be manually transferred and uploaded to the object storage utilized by the Cloudera AI Registry and Cloudera AI Inference service.
- Configure AWS CLI with the appropriate Ozone credentials.
- Generate the Ozone S3 secret key and Ozone access key.
- SSH to the Cloudera Manager host. You can find the hostname in .
Check for a valid Kerberos ticket by using the
klistcommand.If a valid Kerberos ticket is not listed run the following command with the configured Keytab:# kinit -kt /cdep/keytabs/om.keytab om Run klist to check if kerberos ticket is granted. [root@cml-pvc-oldap-1 ~]# klist Ticket cache: FILE:/tmp/krb5cc_0 Default principal: om@CDSW-INT.CLOUDERA.COM Valid starting Expires Service principal 05/25/2022 14:32:13 05/26/2022 14:32:13 krbtgt/CDSW-INT.CLOUDERA.COM@CDSW-INT.CLOUDERA.COM renew until 06/02/2022 14:32:13 -
Get the Ozone S3 secret key, that is the
awsSecretand the Ozone access key, that isawsAccessKeyby running the following command:[root@cml-pvc-oldap-1 ~]# ozone s3 getsecret --om-service-id=ozone1 awsAccessKey=om@CDSW-INT.CLOUDERA.COM awsSecret=40d5fc02fc882d53df3758a76184eb810ee97d9e1c45e5a7f2ef715bf31e5a0a
Copy the awsAccessKey and awsSecret keys for configuring AWS CLI by executing the
aws configurecommand:aws configure AWS Access Key ID [****************PAOF]: AWS Secret Access Key [****************U4Fz]: Default region name [None]: Default output format [None]:
import_to_airgap.py script.
The script is used to upload the downloaded Model artifacts to a secured
location in Cloudera on premises. The
destination format must be s3://bucket/secured-models. This
bucket location can be modified by the Administrator to have a different
value, as for example, s3://newBucket/not-secured .
You can use the parameters listed in the Parameters for uploading the Models table for uploading the Models.
| Parameter | Description | Example |
-i |
Runs in insecure mode and skips SSL verification. This parameter is valid only for on premises environments, but Cloudera does not recommend it for production use cases. You must fetch the CA certificate to be used for the on-premises environment. | -i |
-ca |
Specifies the certificate to be used for Ozone S3 gateway communication. | -ca /path/to/cert.pem |
-e |
Specifies the Ozone S3 gateway endpoint URL | -e
https://ccycloud-5.cml-cai.root.comops.site:9879 |
-c |
Specifies the on-premises Cloud type | -c pvc |
-s |
This source directory must contain the previously downloaded Model artifacts. | -s $PWD/models |
-d |
Specifies the Cloudera AI Registry
bucket with the appropriate path. The destination format must be: s3://bucket/secured-models |
-d s3://bucket/secured-models |
-rt |
Specifies the repository type, either Hugging Face or NVIDIA NGC | -rt hf |
-ri |
Specifies the repository ID of the Model downloaded to the local filesystem |
You can obtain the
ri argument for
Hugging Face by performing the following actions:
--account |
Specifies the Azure storage account name | --account
$AZURE_STORAGE_ACCOUNT_NAME |
--container |
Specifies the Azure storage container name | --container data |
upload: ../.airgap/model/hf/hf-tiny-model-private/tiny-random-YosoModel/artifacts/pytorch\_model.bin to s3://[***BUCKET NAME***]/secured-models /hf/hf-tiny-model-private/tiny-random-YosoModel/artifacts/pytorch\_model.binUploaded: /root/.airgap/model/hf/hf-tiny-model-private/tiny-random-YosoModel -> s3://[***BUCKET NAME***]/secured-models/hf/hf-tiny-model-private/tiny-random-YosoModel
Finish uploading hf repository: hf-tiny-model-private/tiny-random-YosoModel to aws
Upload completed for repository: hf-tiny-model-private/tiny-random-YosoModel to aws
s3://bucket/secured-models:
s3://[***BUCKET NAME***]/secured-models/hf/hf-tiny-model-private/tiny-random-YosoModelChanging the default model upload location
The default model upload location is set to
s3://bucket/secured-models, where bucket
corresponds to the bucket used during the setup of Cloudera AI Registry. To change this default upload location, for
example, to s3://bucket1/another-secured-models, make an API call
to Cloudera AI Registry.
# python import_to_airgap.py --list-local-models
=== LOCAL MODELS ===
Repo Type Repo ID Download Success Num Retries
hf hf-tiny-model-private/tiny-random-YosoModel true 0
After the API call is successfully executed, the new upload location is ready for use.
icon next to the name of
the model, and copy the model ID. Use this ID as
the
