Tracking model metrics without deploying a model
Cloudera recommends that you develop and test model metrics in a workbench session before actually deploying the model. This workflow avoids the need to rebuild and redeploy a model to test every change.
Metrics tracked in this way are stored in a local, in-memory datastore instead of the metrics
database, and are no longer stored when the session exits. You can access these metrics in the
same session using the regular metrics API in the cdsw.py
file.
The following example demonstrates how to track metrics locally within a session, and use the
read_metrics
function to read the metrics in the same session by querying
by the time window.
use_model_metrics.py
predict_with_metrics.py
The predict function from the predict_with_metrics.py
file shown in the
following example is similar to the function with the same name in the
predict.py
file. It takes input and returns output, and can be deployed as
a model. But unlike the function in the predict.py
file, the predict function
file tracks mathematical metrics. These
metrics can include information such as input, output, feature values, convergence metrics,
and error estimates. In this simple example, only input and output are tracked. The function
is equipped to track metrics by applying the decorator
models.cml_model(metrics=True)
import pickle
import cml.metrics_v1 as metrics
import cml.models_v1 as models
model = pickle.load(open('model.pkl', 'rb'))
# The model_metrics decorator equips the predict function to
# call track_metrics. It also changes the return type. If the
# raw predict function returns a value "result", the wrapped
# function will return eg
# "uuid": "612a0f17-33ad-4c41-8944-df15183ac5bd",
# "prediction": "result"
# The UUID can be used to query the stored metrics for this
# prediction later.
@models.cml_model(metrics=True)
def predict(args):
# Track the input.
metrics.track_metric("input", args)
# If this model involved features, ie transformations of the
# raw input, they could be tracked as well.
# cdsw.track_metric("feature_vars", {"a":1,"b":23})
petal_length = float(args.get('petal_length'))
result = model.predict([[petal_length]])
# Track the output.
metrics.track_metric("predict_result", result[0][0])
return result[0][0]
You can fetch the metrics from the local, in-memory datastore by using the regular
metrics API. To fetch the metrics, set the dev
keyword argument to
True
in the use_model_metrics.py
file. You can query the
metrics by model, model build, or model deployment using the variables
cdsw.dev_model_crn
and cdsw.dev_model_build_crn or
cdsw.dev_model_deploy_crn
respectively.
end_timestamp_ms=int(round(time.time() * 1000))
cdsw.read_metrics(model_deployment_crn=cdsw.dev_model_deployment_crn,
start_timestamp_ms=0,
end_timestamp_ms=end_timestamp_ms,
dev=True)
where CRN denotes Cloudera Resource Name, which is a unique identifier from Cloudera, analogous to Amazon's ARN.
