alertmanager_build_info metric
CDP Private Cloud Data Service metrics for alertmanager_build_info.
Name
Description
A metric with a constant '1' value labeled by version, revision, branch, goversion from which alertmanager was built, and the goos and goarch for the build.
Type
GAUGE
Labels
  • branch
  • goarch
  • goos
  • goversion
  • revision
  • tags
  • version
Unit
Aggregates
Meta
  • Category: monitoring
  • Deployment: monitoring-prometheus-alertmanager
Additional Notes
null
Version
null
