coredns_build_info metric
CDP Private Cloud Data Service metrics for coredns_build_info.
Name
coredns_build_info
Description
A metric with a constant '1' value labeled by version, revision, and goversion from which CoreDNS was built.
Type
GAUGE
Labels
  • goversion
  • revision
  • version
Unit
Aggregates
Meta
  • Category: monitoring
  • Deployment: rke2-coredns-rke2-coredns
Additional Notes
null
Version
null
