alertmanager_build_info metric
Cloudera Data Services on premises metrics for alertmanager_build_info.
- Name
- alertmanager_build_info
- Description
- A metric with a constant '1' value labeled by version, revision, branch, goversion from which alertmanager was built, and the goos and goarch for the build.
- Type
- GAUGE
- Labels
- branch
- goarch
- goos
- goversion
- revision
- tags
- version
- Unit
- Aggregates
- Meta
- Category: monitoring
- Deployment: monitoring-prometheus-alertmanager
- Additional Notes
- null
- Version
- null
