coredns_build_info metric
Cloudera Data Services on premises metrics for coredns_build_info.
- Name
- coredns_build_info
- Description
- A metric with a constant '1' value labeled by version, revision, and goversion from which CoreDNS was built.
- Type
- GAUGE
- Labels
- goversion
- revision
- version
- Unit
- Aggregates
- Meta
- Category: monitoring
- Deployment: rke2-coredns-rke2-coredns
- Additional Notes
- null
- Version
- null
