monitoring_remote_write_configuration_failed metric
Cloudera Data Services on premises metrics for monitoring_remote_write_configuration_failed.
- Name
- monitoring_remote_write_configuration_failed
- Description
- The value is 1 if the prometheus remote-write configuration was not distributed successfully
- Type
- GAUGE
- Labels
- Unit
- Aggregates
- Meta
- Category: monitoring
- Deployment: cdp-release-monitoring-controller-manager
- Additional Notes
- null
- Version
- null
