node_hwmon_temp_max_celsius metric
Cloudera Data Services on premises metrics for node_hwmon_temp_max_celsius.
- Name
- node_hwmon_temp_max_celsius
- Description
- Hardware monitor for temperature (max)
- Type
- GAUGE
- Labels
- chip
- sensor
- Unit
- Aggregates
- Meta
- Category: monitoring
- Deployment: prometheus-node-exporter-1.6.0
- Additional Notes
- null
- Version
- null
