process_virtual_memory_max_bytes metric
Cloudera Data Services on premises metrics for process_virtual_memory_max_bytes.
- Name
- process_virtual_memory_max_bytes
- Description
- Maximum amount of virtual memory available in bytes.
- Type
- GAUGE
- Labels
- Unit
- Aggregates
- Meta
- Category: monitoring
- Deployment: monitoring-prometheus-alertmanager
- Additional Notes
- null
- Version
- null
