Setting up and using a resource plan
Understanding the prerequisites for using workload management is critical. As administrator, you can define a resource plan using DDL statements that typically include event-triggered resource pools for different users or applications. You can then manage workloads using the resource plan. After creating and enabling a resource plan, you must activate it. When you want to alter a resource plan or stop using it, you must disable it.
