developing spark applicationsPDF version
Accessing Spark SQL through the Spark shell
Use the following steps to access Spark SQL using the Spark shell.
spark-shell --num-executors 1 --executor-memory 512m --master yarn-client
To read data by interacting with the Hive Metastore, construct a HiveContext instance (HiveContext extends SQLContext). For an example of the use of HiveContext (instantiated as val sqlContext), see "Accessing ORC Files from Spark" in this guide.
