Using Spark Hive Warehouse and HBase Connector Client .jar files with Livy
This section describes how to use Spark Hive Warehouse Connector (HWC) and Spark HBase Connector (SHC) client .jar files with Livy. These steps are required to ensure token acquisition and avoid authentication errors.
Use the following steps to use Spark HWC and SHC client .jar files with Livy:
- Copy the applicable HWC or SHC .jar files to the Livy server node and add these
folders to the
livy.file.local-dir-whitelistproperty in thelivy.conffile. - Add the required configurations in the
/usr/hdp/current/spark2-client/conffolder:Or add the required configurations using the- For Hive, in
/usr/hdp/current/spark2-client/conf/hive-site.xml - For HBase, in
/usr/hdp/current/spark2-client/conf/hbase-site.xml).
conffield in the session creation request. This is equivalent to using "--conf" in spark-submit. - For Hive, in
- Reference these local .jar files in the session creation request using the
file:///URI format.
HWC Example
- Add the add the following folders to the
livy.file.local-dir-whitelistproperty in thelivy.conffile./usr/hdp/current/hive_warehouse_connector/ - Add
hive-site.xmlto/usr/hdp/current/spark2-client/confon all cluster nodes. - When running using the Zeppelin Livy interpreter, reference the HWC .jar file as
shown below.
%livy2.conf livy.spark.jars file:///usr/hdp/current/hive_warehouse_connector/hive-warehouse-connector-assembly-1.0.0.3.0.0.0-1634.jar
SHC Example
livy.file.local-dir-whitelistproperty in thelivy.conffile./usr/hdp/current/hbase-client/lib, /usr/hdp/current/shc - Add
hbase-site.xmlto/usr/hdp/current/spark2-client/confon all cluster nodes. - When running using the Zeppelin Livy interpreter, reference the following HBase
.jar files as shown below. Note that some of these .jar files have 644/root
permissions, and therefore may throw an exception. If this happens, you may need
to change the permissions of the applicable .jar files on the Livy node.
%livy2.conf livy.spark.jars file:///usr/hdp/current/shc/shc-core-1.1.0.3.0.1.0-65.jar, file:///usr/hdp/current/hbase-client/lib/hbase-shaded-protobuf-2.1.0.jar, file:///usr/hdp/current/hbase-client/lib/hbase-shaded-miscellaneous-2.1.0.jar, file:///usr/hdp/current/hbase-client/lib/hbase-protocol-shaded.jar, file:///usr/hdp/current/hbase-client/lib/hbase-shaded-netty-2.1.0.jar, file:///usr/hdp/current/hbase-client/lib/hbase-shaded-client.jar, file:///usr/hdp/current/hbase-client/lib/hbase-shaded-mapreduce.jar, file:///usr/hdp/current/hbase-client/lib/hbase-common.jar, file:///usr/hdp/current/hbase-client/lib/hbase-server.jar, file:///usr/hdp/current/hbase-client/lib/hbase-client.jar, file:///usr/hdp/current/hbase-client/lib/hbase-protocol.jar, file:///usr/hdp/current/hbase-client/lib/hbase-mapreduce.jar, file:///usr/hdp/current/hbase-client/lib/guava-11.0.2.jar
