Using Spark SQL
This section provides information about using Spark SQL.
Interactive access using the Spark shell (see "Accessing Spark SQL through the Spark Shell" in this guide).
From an application, operating through one of the following two APIs and the HiveServer2:
JDBC, using your own Java code or the Beeline JDBC client
ODBC, through the Simba ODBC driver
The following subsections describe how to access Spark SQL through the Spark shell, and through JDBC and ODBC.
