Enabling Spark rolling event log files in CDP
While running a long-running Spark application in CDP, (for example, a streaming application), the Spark Job generates a large single event log file until the Spark application is killed or stopped. A single event log file is not cost effective, requires high maintenance, and is resource-intensive. Therefore, to avoid creating a large event log file, you can use a rolling event log file.
If the Spark application is still running, only the spark.history.fs.eventLog.rolling.maxFilesToRetain / spark.history.fs.eventLog.rolling.compaction.score.threshold parameters are considered (the spark.history.fs.cleaner.maxAge parameter is not used in this case).
  1. Navigate to Cloudera Manager > Spark 3 > Configuration > Spark 3 Client Advanced Configuration Snippet (Safety Valve) for spark3-conf/spark-defaults.conf and set the following properties:
    spark.eventLog.rolling.enabled=true
    spark.eventLog.rolling.maxFileSize=128m
    The default spark.eventLog.rolling.maxFileSize value is 128 MB. The minimum value allowed is 10 MB.
  2. Set the maximum number of rolling event log files to retain:
    1. Navigate to Cloudera Manager > Spark 3> Configuration > History Server Advanced Configuration Snippet (Safety Valve) for spark3-conf/spark-history-server.conf and set the following property:
      spark.history.fs.eventLog.rolling.maxFilesToRetain=2
      By default, spark.history.fs.eventLog.rolling.maxFilesToRetain value is infinity, meaning all event log files are retained. Therefore, this parameter needs to be specified to avoid retaining more files. The minimum value allowed is 1.
  3. Verify the output from the Spark history server event log directory. An example output is displayed below:
[root@c3543-node4 ~]# sudo -u spark hdfs dfs -ls -R /user/spark/spark3ApplicationHistory/eventlog_v2_application_1672813574470_0002 -rw-rw---- 3 spark spark 0 2023-01-04 07:03 /user/spark/spark3ApplicationHistory/eventlog_v2_application_1672813574470_0002/appstatus_application_1672813574470_0002.inprogress -rw-rw---- 3 spark spark 10485458 2023-01-04 07:05 /user/spark/spark3ApplicationHistory/eventlog_v2_application_1672813574470_0002/events_1_application_1672813574470_0002 -rw-rw---- 3 spark spark 0 2023-01-04 07:05 /user/spark/spark3ApplicationHistory/eventlog_v2_application_1672813574470_0002/events_2_application_1672813574470_0002 [root@c3543-node4 ~]# sudo -u spark hdfs dfs -ls -R /user/spark/spark3ApplicationHistory/eventlog_v2_application_1672813574470_0002 -rw-rw---- 3 spark spark 0 2023-01-04 07:03 /user/spark/spark3ApplicationHistory/eventlog_v2_application_1672813574470_0002/appstatus_application_1672813574470_0002.inprogress -rw-rw---- 3 spark spark 492014 2023-01-04 07:06 /user/spark/spark3ApplicationHistory/eventlog_v2_application_1672813574470_0002/events_1_application_1672813574470_0002.compact -rw-rw---- 3 spark spark 10489509 2023-01-04 07:06 /user/spark/spark3ApplicationHistory/eventlog_v2_application_1672813574470_0002/events_2_application_1672813574470_0002 -rw-rw---- 3 spark spark 227068 2023-01-04 07:06 /user/spark/spark3ApplicationHistory/eventlog_v2_application_1672813574470_0002/events_3_application_1672813574470_0002 [root@c3543-node4 ~]# sudo -u spark hdfs dfs -ls -R /user/spark/spark3ApplicationHistory/eventlog_v2_application_1672813574470_0002 -rw-rw---- 3 spark spark 0 2023-01-04 07:03 /user/spark/spark3ApplicationHistory/eventlog_v2_application_1672813574470_0002/appstatus_application_1672813574470_0002.inprogress -rw-rw---- 3 spark spark 873356 2023-01-04 07:06 /user/spark/spark3ApplicationHistory/eventlog_v2_application_1672813574470_0002/events_2_application_1672813574470_0002.compact -rw-rw---- 3 spark spark 10484816 2023-01-04 07:06 /user/spark/spark3ApplicationHistory/eventlog_v2_application_1672813574470_0002/events_3_application_1672813574470_0002 -rw-rw---- 3 spark spark 339165 2023-01-04 07:06 /user/spark/spark3ApplicationHistory/eventlog_v2_application_1672813574470_0002/events_4_application_1672813574470_0002
