Running YARN Services
You can use YARN Services API to manage YARN services. You can use the YARN CLI to view the logs for running applications. In addition, you can use YARN distributed cache to deploy multiple versions of Mapreduce.
Previously, deploying a new service on YARN was not a simple experience. The APIs of existing frameworks were either too low level (native YARN), required writing new code (for frameworks with programmatic APIs), or required writing a complex specification (for declarative frameworks). Apache Slider was developed to run services such as HBase, Storm, Accumulo, and Solr on YARN by exposing higher-level APIs that supported running these services on YARN without modification.
The new YARN Services API greatly simplifies the deployment and management of YARN services.
