You can use the YARN
Services API to manage long-running YARN applications.
You can use the YARN Services API to deploy and manage the YARN services.
Use the YARN Services API to run a POST operation on your application,
specifying a long or unlimited lifetime in the POST attributes.
Use the YARN Services API to manage your application.
- Increase or decrease the number of application instances.
- Perform other application life cycle tasks.
