Cloudera Documentation
Example: Running SparkPi on YARN
These examples demonstrate how to use spark-submit to submit the SparkPi Spark example application with various options. In the examples, the argument passed after the JAR controls how close to pi the approximation should be.
In a CDP deployment, SPARK_HOME defaults to /opt/cloudera/parcels/CDH/lib/spark. The shells are also available from /bin.
To run SparkPi in cluster mode:
spark-submit --class org.apache.spark.examples.SparkPi --master yarn \
--deploy-mode cluster /opt/cloudera/parcels/CDH/jars/spark-examples*.jar 10
The command prints status until the job finishes or you press control-C. Terminating the spark-submit process in cluster mode does not terminate the Spark application as it does in client mode. To monitor the status of the running application, run yarn application -list.
To run SparkPi in client mode:
--deploy-mode client SPARK_HOME/lib/spark-examples.jar 10
  1. Unpack the Python examples archive:
    sudo su gunzip SPARK_HOME/lib/python.tar.gz
    sudo su tar xvf SPARK_HOME/lib/python.tar
  2. Run the pi.py file:
    spark-submit --master yarn --deploy-mode cluster SPARK_HOME/lib/pi.py 10
