Cloudera Documentation
Canary test for pyspark command
The following example shows a simple pyspark session that refers to the SparkContext, calls the collect() function which runs a Spark 2 job, and writes data to HDFS. This sequence of operations helps to check if there are obvious configuration issues that prevent Spark jobs from working at all. For the HDFS path for the output directory, substitute a path that exists on your own system.
$ hdfs dfs -mkdir /user/systest/spark
$ pyspark
>>> strings = ["one","two","three"]
>>> s2 = sc.parallelize(strings)
>>> s3 = s2.map(lambda word: word.upper())
>>> s3.collect()
['ONE', 'TWO', 'THREE']
>>> s3.saveAsTextFile('hdfs:///user/systest/spark/canary_test')
>>> quit()
$ hdfs dfs -ls /user/systest/spark
Found 1 items
drwxr-xr-x   - systest supergroup          0 2016-08-26 14:41 /user/systest/spark/canary_test
$ hdfs dfs -ls /user/systest/spark/canary_test
Found 3 items
-rw-r--r--   3 systest supergroup          0 2016-08-26 14:41 /user/systest/spark/canary_test/_SUCCESS
-rw-r--r--   3 systest supergroup          4 2016-08-26 14:41 /user/systest/spark/canary_test/part-00000
-rw-r--r--   3 systest supergroup         10 2016-08-26 14:41 /user/systest/spark/canary_test/part-00001
$ hdfs dfs -cat /user/systest/spark/canary_test/part-00000
ONE
$ hdfs dfs -cat /user/systest/spark/canary_test/part-00001
TWO
THREE
