When to Add a Shuffle Transformation
The rule of minimizing the number of shuffles has some exceptions.
          An extra shuffle can be advantageous when it increases parallelism. For example, if
          your data arrives in a few large unsplittable files, the partitioning dictated by the
          InputFormat might place large numbers of records in each partition,
          while not generating enough partitions to use all available cores. In this case,
          invoking repartition with a high number of partitions (which triggers a shuffle) after
          loading the data allows the transformations that follow to use more of the cluster's
          CPU.
          Another example arises when using the reduce or
          aggregate action to aggregate data into the driver. When aggregating
          over a high number of partitions, the computation can quickly become bottlenecked on a
          single thread in the driver merging all the results together. To lighten the load on
          the driver, first use reduceByKey or aggregateByKey
          to perform a round of distributed aggregation that divides the dataset into a smaller
          number of partitions. The values in each partition are merged with each other in
          parallel, before being sent to the driver for a final round of aggregation. See
            treeReduce
          and
            treeAggregate
          for examples of how to do that.
          This method is especially useful when the aggregation is already grouped by a key. For
          example, consider an application that counts the occurrences of each word in a corpus
          and pulls the results into the driver as a map. One approach, which can be
          accomplished with the aggregate action, is to compute a local map at
          each partition and then merge the maps at the driver. The alternative approach, which
          can be accomplished with aggregateByKey, is to perform the count in a
          fully distributed way, and then simply collectAsMap the results to
          the driver.
