Running Apache Spark 3.5.8 applications
You can run Apache Spark 3.5.8 applications locally or distributed across a cluster, either by using an interactive shell or by submitting an application. Running Spark applications interactively is commonly performed during the data-exploration phase and for ad hoc analysis.
Apache Spark 3.5.8 ships in Cloudera Runtime 7.3.2.10000 SP1 and higher on the 7.3.2 line (Apache Spark 3.5.4 in 7.3.2.0). For cluster upgrade steps, see Upgrading Spark and Upgrading Apache Spark 3.5.4 to Spark 3.5.8. For application migration, behavior changes, and JDK 17 guidance, see Migrating Spark applications and the Apache Spark 3.5.8 documentation.
Submit jobs with Livy
You can submit and manage Spark 3 jobs through Livy using programmatic and REST APIs. Livy supports Scala 2.12 for Spark 3 workloads. For API overview and Scala configuration, see Using the Livy API to run Spark jobs. For submission options and security features, see Submitting Spark applications using Livy.
spark-shell on JDK 17
On clusters that run JDK 17, the Java Platform Module System (JPMS) enforces strong encapsulation on java.base. The interactive Scala REPL used by spark-shell must resolve Java base classes through the application classpath. If the driver JVM does not include -Dscala.usejavacp=true, spark-shell initialization can fail with errors such as:
[init] error: error while loading Object, Missing dependency 'object scala.native in compiler mirror', required by /modules/java.base/java/lang/Object.class
Failed to initialize compiler: object scala in compiler mirror not found.
Pre-compiled jobs submitted with spark-submit and interactive pyspark sessions are not affected.
In Cloudera Manager:
  1. Navigate to Clusters > Spark 3 > Configuration.
  2. Search for Spark 3 Client Advanced Configuration Snippet (Safety Valve) for spark3-conf/spark-defaults.conf (or spark-defaults.conf).
  3. Append -Dscala.usejavacp=true to spark.driver.extraJavaOptions. For example:
    spark.driver.extraJavaOptions=-Dscala.usejavacp=true --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.util=ALL-UNNAMED --add-opens=java.base/java.io=ALL-UNNAMED --add-opens=java.base/java.net=ALL-UNNAMED --add-opens=java.base/java.nio=ALL-UNNAMED --add-opens=java.base/java.security=ALL-UNNAMED --add-opens=java.base/sun.reflect.annotation=ALL-UNNAMED
  4. Click Save Changes.
  5. Redeploy client configuration for Spark 3 (Stale Configuration → Deploy Client Configuration).
Unsupported connectors
This release does not support the following connectors:
  • SparkR
Limitations of Spark in Cloudera
Limitations of Spark (in comparison to upstream Apache Spark 3.5.8) in Cloudera are described below:
  • spark.sql.orc.compression.codec config doesn't accept zsdt value.
  • Push-based shuffle is not supported
Canary test for pyspark command
The following example shows a simple pyspark session that refers to the SparkContext, calls the collect() function which runs a Spark 3 job, and writes data to HDFS. This sequence of operations helps to check if there are obvious configuration issues that prevent Spark 3 jobs from working at all. For the HDFS path for the output directory, substitute a path that exists on your own system.
$ hdfs dfs -mkdir /user/jdoe/spark
$ pyspark
>>> strings = ["one","two","three"]
>>> s2 = sc.parallelize(strings)
>>> s3 = s2.map(lambda word: word.upper())
>>> s3.collect()
['ONE', 'TWO', 'THREE']
>>> s3.saveAsTextFile('hdfs:///user/jdoe/spark/canary_test')
>>> quit()
$ hdfs dfs -ls /user/jdoe/spark
Found 1 items
drwxr-xr-x   - jdoe spark-users  0 2016-08-26 14:41 /user/jdoe/spark/canary_test
$ hdfs dfs -ls /user/jdoe/spark/canary_test
Found 3 items
-rw-r--r--   3 jdoe spark-users  0 2016-08-26 14:41 /user/jdoe/spark/canary_test/_SUCCESS
-rw-r--r--   3 jdoe spark-users  4 2016-08-26 14:41 /user/jdoe/spark/canary_test/part-00000
-rw-r--r--   3 jdoe spark-users 10 2016-08-26 14:41 /user/jdoe/spark/canary_test/part-00001
$ hdfs dfs -cat /user/jdoe/spark/canary_test/part-00000
ONE
$ hdfs dfs -cat /user/jdoe/spark/canary_test/part-00001
TWO
THREE
Fetching Spark 3 Maven Dependencies
The Maven coordinates are a combination of groupId, artifactId and version. The groupId and artifactId are the same as for the upstream Apache Spark project. For example, for spark-core, groupId is org.apache.spark, and artifactId is spark-core_2.12, both the same as the upstream project. The version is different for the Cloudera packaging, it contains the upstream Spark version as well as the Cloudera version: [**artifactId***]-[***UPSTREAM SPARK VERSION***].[***CDP VERSION***]-[***CLOUDERA BUILD NUMBER***]. Use the Cloudera Runtime release notes or Maven repository documentation for your deployment to obtain the exact version string for Spark 3.5.8.
Accessing the Spark 3 History Server
The Spark 3 history server is available on port 18089, rather than port 18088 as with the Spark 2 history server.
