4.1. Problem: Hive developers may encounter an exception error message during Hive
Service Check
MySQL is the default database used by the Hive metastore. Depending on several
factors, such as the version and configuration of MySQL, a Hive developer may see an
exception message similar to the following one:
Administrators can resolve this issue by altering the Hive metastore database
to use the Latin1 character set, as shown in the following example:
mysql> ALTER DATABASE {metastore_database_name} character set latin1;
4.2. Problem: API calls for PUT, POST, DELETE respond with a "400 - Bad Request"
Removing a registered host not added to a cluster. curl command and REST API calls
require a header element.
For example, if using curl, include the -H "X-Requested-By: ambari"
option.
curl -u admin:admin -H "X-Requested-By: ambari" -X DELETE http://{ambari-host}:8080/api/v1/hosts/host1
4.3. Problem: Nagios alerts for CPU utilization show as UNKNOWN
Alerts for Master components such as "NameNode CPU Utilization" and "ResourceManager CPU Utilization" show as "UNKNOWN".
Nagios uses Simple Network Management Protocol (SNMP) to check CPU
utilization. Be sure SNMP is started and port 161 is accessible between the
Nagios Server and the hosts running the Master components.
service snmpd start
