1.1. Terms and Definitions
The following basic terms help describe the key concepts associated with Ambari Alerts:
Terminology
Term
Definition
Alert Definition
Defines the alert including the description, check interval, type and thresholds.
Type
The type of alert, such as PORT or METRIC.
State
Indicates the state of an alert definition. Enabled or disabled. When disabled, no alert instances are created.
Alert Instance
Represents the specific alert instances based on an alert definition. For example, the alert definition for DataNode process will have an alert instance per DataNode in the cluster.
Status
An alert instance status is defined by severity. The most common severity levels are OK, WARN, CRIT but there are also severities for UNKNOWN and NONE. See “Alert Instances” for more information.
Threshold
The thresholds assigned to each status.
Alert Group
Grouping of alert definitions, useful for handling notifications targets.
Notification
A notification target for when an alert instance status changes. Methods of notification include EMAIL and SNMP.
