5.1. During Enable Kerberos, the Check Kerberos operation fails.
Check that NTP is running and confirm your hosts and the KDC times are in sync. A time
skew as little as 5 minutes can cause Kerberos authentication to fail.
5.1.2. Solution 2: (on RHEL/CentOS/Oracle Linux)
Check that the Kerberos Admin principal being used has the necessary KDC ACL rights as
set in /var/kerberos/krb5kdc/kadm5.acl
5.2. Problem: Hive developers may encounter an exception error message during Hive Service Check
Administrators can resolve this issue by altering the Hive metastore database to use
the Latin1 character set, as shown in the following example: mysql> ALTER
DATABASE
<metastore.database.name> character set
latin1;
5.3. Problem: API calls for PUT, POST, DELETE respond with a "400 - Bad Request"
Starting with Ambari 1.4.2, you must include the "X-Requested-By" header
with the REST API calls.
For example, if using curl, include the -H "X-Requested-By:
ambari"
option. curl -u admin:admin -H "X-Requested-By:
ambari" -X DELETE
http://<ambari-host>:8080/api/v1/hosts/host1
