6. Resolving General Problems
 6.1. During Enable Kerberos, the Check Kerberos operation fails.
 6.1.1. Solution 1:
 6.1.2. Solution 2: (on RHEL/CentOS/Oracle Linux)
Check that the Kerberos Admin principal being used has the necessary KDC ACL rights as set in /var/kerberos/krb5kdc/kadm5.acl .
 6.2. Problem: Hive developers may encounter an exception error message during Hive Service Check
 6.2.1. Solution
Administrators can resolve this issue by altering the Hive metastore database to use the Latin1 character set, as shown in the following example: mysql> ALTER DATABASE <metastore.database.name> character set latin1;
 6.3. Problem: API calls for PUT, POST, DELETE respond with a "400 - Bad Request"
 6.3.1. Solution
For example, if using curl, include the -H "X-Requested-By: ambari" option. curl -u admin:admin -H "X-Requested-By: ambari" -X DELETE http://<ambari-host>:8080/api/v1/hosts/host1
 6.4. Problem: Ambari is checking disk full on non-local disks; causing a high number of auto-mounted home directories
When Ambari issues it's check to detect local disk capacity and use for each Ambari Agent, it uses df by default instead of df -l to only check local disks. If using NFS auto-mounted home directories, this can lead to a high number of home directories being mounted on each host; causing shutdown delays and disk capacity check delays.
 6.4.1. Solution:
On the Ambari Server, edit the /etc/ambari-server/conf/ambari.properties and add the following property to only check locally mounted devices.
 6.5. Problem: Links in pdf documentation not working.
Links in 2.1.1. pdf documentation not working.
 6.5.1. Solution:
Use working links from 2.1.1 html documentation.
