5. Resolving General Problems
 5.1. Problem: After upgrading to Ambari 2.1.2, you receive File Does Not Exist alerts.
After upgrading to Ambari 2.1.2, you receive alerts for "DataNode Unmounted Data Dir" that the /var/lib/ambari-agent/data/datanode/dfs_data_dir_mount.hist file does not exist. The hadoop-env/dfs.datanode.data.dir.mount.file configuration property is no longer customizable from Ambari. The original default value of /etc/hadoop/conf/dfs_data_dir_mount.hist is now /var/lib/ambari-agent/data/datanode/dfs_data_dir_mount.hist, which is not customizable. On Ambari Agent upgrade, Ambari will automatically move the file from /etc/hadoop/conf/dfs_data_dir_mount.hist to /var/lib/ambari-agent/data/datanode/dfs_data_dir_mount.hist. If you have not modified this configuration property, no action is required.
 5.1.1. Solution:
If you had previously modified the hadoop-env/dfs.datanode.data.dir.mount.file value to a custom location, after upgrading to Ambari 2.1.2, you must restart your DataNodes for the file to written to be the new location.
 5.2. During Enable Kerberos, the Check Kerberos operation fails.
 5.2.1. Solution 1:
 5.2.2. Solution 2: (on RHEL/CentOS/Oracle Linux)
Check that the Kerberos Admin principal being used has the necessary KDC ACL rights as set in /var/kerberos/krb5kdc/kadm5.acl .
 5.3. Problem: Hive developers may encounter an exception error message during Hive Service Check
 5.3.1. Solution
Administrators can resolve this issue by altering the Hive metastore database to use the Latin1 character set, as shown in the following example: mysql> ALTER DATABASE <metastore.database.name> character set latin1;
 5.4. Problem: API calls for PUT, POST, DELETE respond with a "400 - Bad Request"
 5.4.1. Solution
For example, if using curl, include the -H "X-Requested-By: ambari" option. curl -u admin:admin -H "X-Requested-By: ambari" -X DELETE http://<ambari-host>:8080/api/v1/hosts/host1
 5.5. Problem: Ambari is checking disk full on non-local disks; causing a high number of auto-mounted home directories
When Ambari issues it's check to detect local disk capacity and use for each Ambari Agent, it uses df by default instead of df -l to only check local disks. If using NFS auto-mounted home directories, this can lead to a high number of home directories being mounted on each host; causing shutdown delays and disk capacity check delays.
 5.5.1. Solution:
On the Ambari Server, edit the /etc/ambari-server/conf/ambari.properties and add the following property to only check locally mounted devices.
 5.6. Problem: Links in pdf documentation not working.
Links in 2.1.1. pdf documentation not working.
 5.6.1. Solution:
Use working links from 2.1.1 html documentation.
 5.7. Problem: Ambari Web shows Storm summary values as N/A in a Kerberized cluster
24 Mar 2015 13:32:41,
288 ERROR [pool-2-thread-362]
AppCookieManager:122 -
SPNego authentication failed,
cannot get hadoop.auth cookie for URL:
http: //c6402.ambari.apache.org:8744/api/
v1/topology/summary?field=topologies
 5.7.1. Solution:
 5.8. Problem: kadmin running Ambari Server as non-root, cannot open log file.
STDERR: Couldn't open log file /var/log/kadmind.log: Permission denied
kadmin: GSS-API (or Kerberos) error while initializing kadmin interface
 5.8.1. Solution:
