Ambari Reference Guide
Using Hive with PostgreSQL
    1. Install the connector.
      RHEL/CentOS/Oracle Linux
      yum install postgresql-jdbc*
      SLES
    3. Change the access mode of the.jar file to 644.
    • Where <HIVEUSER> is the Hive user name, <HIVEPASSWORD> is the Hive user password and <HIVEDATABASE> is the Hive database name.
  3. Load the Hive database schema.
    • For a HDP 2.2 or later Stacks:
      [Important]Important
      You do not need to pre-load the Hive Metastore database schema into your PostgreSQL database for a HDP 2.2 Stack.
    • For HDP 2.1 Stack:
      You must pre-load the Hive database schema into your PostgreSQL database using the schema script, as follows:
      # psql -U <HIVEUSER> -d <HIVEDATABASE> \connect <HIVEDATABASE>; \i hive-schema-0.13.0.postgres.sql;
      Find the hive-schema-0.13.0.postgres.sql file in the /var/lib/ambari-server/resources/stacks/HDP/2.1/services/HIVE/etc/ directory of the Ambari Server host after you have installed Ambari Server.
    • For HDP 2.0 Stack:
      # sudo -u postgres psql \connect <HIVEDATABASE>; \i hive-schema-0.12.0.postgres.sql;
      Find the hive-schema-0.12.0.postgres.sql file in the /var/lib/ambari-server/resources/stacks/HDP/2.0.6/services/HIVE/etc/ directory of the Ambari Server host after you have installed Ambari Server.
