Ambari User's Guide
Widget Descriptions
The Dashboard includes metrics for the following services:
View Metrics that indicate the operating status of your cluster on the Ambari Dashboard. Each metrics widget displays status information for a single service in your HDP cluster. The Ambari Dashboard displays all metrics for the HDFS, YARN, HBase, and Storm services, and cluster-wide metrics by default.
[Note]Note
Metrics data for Storm is buffered and sent as a batch to Ambari every five minutes. After adding the Storm service, anticipate a five-minute delay for Storm metrics to appear.
You can add and remove individual widgets, and rearrange the dashboard by dragging and dropping each widget to a new location in the dashboard.
Status information appears as simple pie and bar charts, more complex charts showing usage and load, sets of links to additional data sources, and values for operating parameters such as uptime and average RPC queue wait times. Most widgets display a single fact by default. For example, HDFS Disk Usage displays a load chart and a percentage figure. The Ambari Dashboard includes metrics for the following services:
Ambari Service Metrics and Descriptions
Metric:
Description:
HDFS
HDFS Disk Usage
The Percentage of DFS used, which is a combination of DFS and non-DFS used.
Data Nodes Live
The number of DataNodes live, as reported from the NameNode.
NameNode Heap
The percentage of NameNode JVM Heap used.
NameNode RPC
The average RPC queue latency.
NameNode CPU WIO
The percentage of CPU Wait I/O.
NameNode Uptime
The NameNode uptime calculation.
YARN (HDP 2.1 or later Stacks)
ResourceManager Heap
The percentage of ResourceManager JVM Heap used.
ResourceManager Uptime
The ResourceManager uptime calculation.
NodeManagers Live
The number of DataNodes live, as reported from the ResourceManager.
YARN Memory
The percentage of available YARN memory (used vs. total available).
HBase
HBase Master Heap
HBase Ave Load
The average load on the HBase server.
HBase Master Uptime
The HBase Master uptime calculation.
Region in Transition
The number of HBase regions in transition.
Storm (HDP 2.1 or later Stacks)
Supervisors Live
The number of Supervisors live, as reported from the Nimbus server.
