Using Oozie with PostgreSQL
On the Ambari Server host, stage the appropriate PostgreSQL connector for later deployment.
Install the connector.
RHEL/CentOS/Oracle Linux
yum install postgresql-jdbc
SLES
Debian/Ubuntu
apt-get install -y libpostgresql-jdbc-java
Confirm that .jar is in the Java share directory.
Change the access mode of the .jar file to 644.
Create a user for Oozie and grant it permissions.
Where <OOZIEUSER> is the Oozie user name, <OOZIEPASSWORD> is the Oozie user password and <OOZIEDATABASE> is the Oozie database name.
