DLM Administration
Tuning DLM Engine
You can tune the DLM Engine for tasks such as running multiple concurrent policies and handling multiple files.
Run Multiple Concurrent Policies
Perform the following steps to run multiple concurrent policies in DLM:
  1. Log in to Ambari.
  2. Set the beacon_quartz_thread_pool property to a value greater than the number of policies required to run concurrently.
Handle Multiple Files
For the DLM Engine to handle multiple files that are listed, ensure that it has sufficient memory.
