Using the NiFi User Interface
Accessing the UI with Multi-Tenant Authorization
Multi-tenant authorization enables multiple groups of users (tenants) to command, control, and observe different parts of the dataflow, with varying levels of authorization. When an authenticated user attempts to view or modify a NiFi resource, the system checks whether the user has privileges to perform that action. These privileges are defined by policies that you can apply system wide or to individual components. What this means from a Dataflow Manager perspective is that once you have access to the NiFi canvas, a range of functionality is visible and available to you, depending on the privileges assigned to you.
The available global access policies are:
Policy Privilege
view the UI
Allows users to view the UI
access the controller
Allows users to view and modify the controller including reporting tasks, Controller Services, and nodes in the cluster
query provenance
Allows users to submit a provenance search and request even lineage
access restricted components
Allows users to create/modify restricted components assuming other permissions are sufficient. The restricted components may indicate which specific permissions are required. Permissions can be granted for specific restrictions or be granted regardless of restrictions. If permission is granted regardless of restrictions, the user can create/modify all restricted components.
access all policies
Allows users to view and modify the policies for all components
access users/groups
Allows users to view and modify the users and user groups
retrieve site-to-site details
Allows other NiFi instances to retrieve Site-To-Site details
view system diagnostics
Allows users to view System Diagnostics
proxy user requests
Allows proxy machines to send requests on the behalf of others
access counters
Allows users to view and modify counters
The available component-level access policies are:
Policy Privilege
view the component
Allows users to view component configuration details
modify the component
Allows users to modify component configuration details
view provenance
Allows users to view provenance events generated by this component
view the data
Allows users to view metadata and content for this component in flowfile queues in outbound connections and through provenance events
modify the data
Allows users to empty flowfile queues in outbound connections and submit replays through provenance events
view the policies
Allows users to view the list of users who can view and modify a component
modify the policies
Allows users to modify the list of users who can view and modify a component
retrieve data via site-to-site
Allows a port to receive data from NiFi instances
send data via site-to-site
Allows a port to send data from NiFi instances
If you are unable to view or modify a NiFi resource, contact your System Administrator or see Configuring Users and Access Policies in the System Administration documentation in the Reference section for more information.
