10. Upgrade Mahout
Upgrade Mahout. On the Mahout client host machine, execute the following command:
  • For RHEL/CentOS:
    yum upgrade mahout-0.7.0.1.3.0.0
  • For SLES:
    zypper remove mahout
    zypper se -s mahout
    You should see Mahout v0.7.0.1.3.0.0 in the output. Install Mahout v0.7.0.1.3.0.0:
    zypper install mahout-0.7.0.1.3.0.0
    [Important]Important
    When removing and installing packages, rename those files the /conf directory that have .rpmsave extension to original to retain the customized configs. Alternatively, you can also use the configuration files (under the /conf directory) you backed up before upgrading.
