9. Upgrade Flume
Upgrade Flume. On the Flume host machine, execute the following command:
  • For RHEL/CentOS:
    yum downgrade flume-1.3.1.1.3.0.0
  • For SLES:
    zypper remove flume
    zypper update flume-1.3.1.1.3.0.0
    zypper se -s flume
    You should see Flume v1.3.1.1.3.0.0 in the output. Install Flume v1.3.1.1.3.0.0:
    zypper install flume-1.3.1.1.3.0.0
    [Important]Important
    When removing and installing packages, rename those files the /conf directory that have .rpmsave extension to original to retain the customized configs. Alternatively, you can also use the configuration files (under the /conf directory) you backed up before upgrading.
