Forming JDBC Connection Strings for Spark SQL
JDBC URL connection strings have the following format:
jdbc:hive2://<host>:<port>/<dbName>;<sessionConfs>?<hiveConfs>#<hiveVars>
JDBC Parameter | Description |
host | The node hosting the Thrift Server. |
port | The port number on which the Thrift Server listens. |
dbName | The name of the Hive database to run the query against. |
sessionConfs | Optional configuration parameters for the JDBC driver, in the following format:
<key1>=<value1>;<key2>=<key2>...; |
hiveConfs |
Optional configuration parameters for Hive on the server in the following
format: These settings last for the duration of the user session. |
hiveVars |
Optional configuration parameters for Hive variables in the following format:
Note | |
The Spark Thrift Server is a variant of HiveServer2, so you can use many of the same settings. For more information, including transport and security settings, see Hive JDBC and ODBC Drivers in the HDP Data Services Guide. |
Accessing Spark via JDBC on a Kerberos-enabled Cluster
The following connection URL accesses Spark SQL via JDBC on a Kerberos-enabled cluster:
beeline> !connect jdbc:hive2://localhost:10002/default;httpPath=/;principal=hive/hdp-team.example.com@EXAMPLE.COM
The following connection URL accesses Spark SQL via JDBC over HTTP transport on a Kerberos-enabled cluster:
beeline> !connect jdbc:hive2://localhost:10002/default;transportMode=http;httpPath=/;principal=hive/hdp-team.example.com@EXAMPLE.COM
