Using the Spark DataFrame API
A DataFrame is a distributed collection of data organized into named columns. It is
conceptually equivalent to a table in a relational database or a data frame in R or in the
Python pandas
library. You can construct DataFrames from a wide array of sources,
including structured data files, Apache Hive tables, and existing Spark resilient distributed
datasets (RDD). The Spark DataFrame API is available in Scala, Java, Python, and R.
This subsection contains several examples of DataFrame API use.
To list JSON file contents as a DataFrame:
As user
spark
, upload thepeople.txt
andpeople.json
files to the Hadoop Distributed File System (HDFS):cd /usr/hdp/current/spark-client su spark hdfs dfs -copyFromLocal examples/src/main/resources/people.txt people.txt hdfs dfs -copyFromLocal examples/src/main/resources/people.json people.json
Launch the Spark shell:
cd /usr/hdp/current/spark-client su spark ./bin/spark-shell --num-executors 1 --executor-memory 512m --master yarn-client
At the Spark shell, type the following:
scala> val df = sqlContext.read.format("json").load("people.json")
Using
df.show
, display the contents of the DataFrame:scala> df.show 16/08/22 11:24:10 INFO YarnScheduler: Removed TaskSet 2.0, whose tasks have all completed, from pool +----+-------+ | age| name| +----+-------+ |null|Michael| | 30| Andy| | 19| Justin| +----+-------+
The following examples use Scala to access DataFrame df
defined in the
previous subsection:
// Import the DataFrame functions API scala> import org.apache.spark.sql.functions._ // Select all rows, but increment age by 1 scala> df.select(df("name"), df("age") + 1).show() // Select people older than 21 scala> df.filter(df("age") > 21).show() // Count people by age scala> df.groupBy("age").count().show()
The following example uses the DataFrame API to specify a schema for
people.txt
, and then retrieves names from a temporary table associated with the
schema:
import org.apache.spark.sql._ val sqlContext = new org.apache.spark.sql.SQLContext(sc) val people = sc.textFile("people.txt") val schemaString = "name age" import org.apache.spark.sql.types.{StructType,StructField,StringType} val schema = StructType(schemaString.split(" ").map(fieldName => StructField(fieldName, StringType, true))) val rowRDD = people.map(_.split(",")).map(p => Row(p(0), p(1).trim)) val peopleDataFrame = sqlContext.createDataFrame(rowRDD, schema) peopleDataFrame.registerTempTable("people") val results = sqlContext.sql("SELECT name FROM people") results.map(t => "Name: " + t(0)).collect().foreach(println)
This produces output similar to the following:
16/08/22 14:36:49 INFO cluster.YarnScheduler: Removed TaskSet 13.0, whose tasks have all completed, from pool 16/08/22 14:36:49 INFO scheduler.DAGScheduler: ResultStage 13 (collect at :33) finished in 0.129 s 16/08/22 14:36:49 INFO scheduler.DAGScheduler: Job 10 finished: collect at :33, took 0.162827 s Name: Michael Name: Andy Name: Justin
