Apache Spark Component Guide
Using the Spark DataFrame API
A DataFrame is a distributed collection of data organized into named columns. It is conceptually equivalent to a table in a relational database or a data frame in R or in the Python pandas library. You can construct DataFrames from a wide array of sources, including structured data files, Apache Hive tables, and existing Spark resilient distributed datasets (RDD). The Spark DataFrame API is available in Scala, Java, Python, and R.
This subsection contains several examples of DataFrame API use.
To list JSON file contents as a DataFrame:
  1. As user spark, upload the people.txt and people.json files to the Hadoop Distributed File System (HDFS):
    cd /usr/hdp/current/spark-client
    su spark
    hdfs dfs -copyFromLocal examples/src/main/resources/people.txt people.txt
    hdfs dfs -copyFromLocal examples/src/main/resources/people.json people.json
  2. Launch the Spark shell:
    su spark
  3. At the Spark shell, type the following:
    scala> val df = sqlContext.read.format("json").load("people.json")
  4. Using df.show, display the contents of the DataFrame:
    scala> df.show
    16/08/22 11:24:10 INFO YarnScheduler: Removed TaskSet 2.0, whose tasks have all completed, from pool
    | age|   name|
    |null|Michael|
    |  30|   Andy|
    |  19| Justin|
The following examples use Scala to access DataFrame df defined in the previous subsection:
// Import the DataFrame functions API
scala> import org.apache.spark.sql.functions._
// Select all rows, but increment age by 1
scala> df.select(df("name"), df("age") + 1).show()
// Select people older than 21
scala> df.filter(df("age") > 21).show()
// Count people by age
scala> df.groupBy("age").count().show()
The following example uses the DataFrame API to specify a schema for people.txt, and then retrieves names from a temporary table associated with the schema:
import org.apache.spark.sql._
val sqlContext = new org.apache.spark.sql.SQLContext(sc)
val people = sc.textFile("people.txt")
val schemaString = "name age"
import org.apache.spark.sql.types.{StructType,StructField,StringType}
val schema = StructType(schemaString.split(" ").map(fieldName => StructField(fieldName, StringType, true)))
val rowRDD = people.map(_.split(",")).map(p => Row(p(0), p(1).trim))
val peopleDataFrame = sqlContext.createDataFrame(rowRDD, schema)
peopleDataFrame.registerTempTable("people")
val results = sqlContext.sql("SELECT name FROM people")
results.map(t => "Name: " + t(0)).collect().foreach(println)
This produces output similar to the following:
16/08/22 14:36:49 INFO cluster.YarnScheduler: Removed TaskSet 13.0, whose tasks have all completed, from pool
16/08/22 14:36:49 INFO scheduler.DAGScheduler: ResultStage 13 (collect at :33) finished in 0.129 s
16/08/22 14:36:49 INFO scheduler.DAGScheduler: Job 10 finished: collect at :33, took 0.162827 s
