Accessing Spark SQL Through the Spark Shell
./bin/spark-shell --num-executors 1 --executor-memory 512m --master
yarn-client
To read data by interacting with the Hive Metastore, construct a HiveContext instance
(HiveContext extends SQLContext). For an example of the use of HiveContext (instantiated as
val sqlContext
), see Accessing ORC Files from Spark.
