Using Spark SQL
Using HiveContext, Spark SQL can also read data by interacting with the Hive MetaStore. If you already use Hive, you should use HiveContext; it supports all Hive data formats and user-defined functions (UDFs), and it enables you to have full access to the HiveQL parser. HiveContext extends SQLContext, so HiveContext supports all SQLContext functionality.
Interactive access using the Spark shell (see Accessing Spark SQL through the Spark Shell).
From an application, operating through one of the following two APIs and the Spark Thrift server:
JDBC, using your own Java code or the Beeline JDBC client
ODBC, through the Simba ODBC driver
For more information about JDBC and ODBC access, see Accessing Spark SQL through JDBC: Prerequisites and Accessing Spark SQL through JDBC and ODBC.
This subsection describes how to access Spark SQL through the Spark shell, and through JDBC and ODBC.
