Optional properties
Property Name Description Default
vault.connection.timeout
The connection timeout of the Vault client
5 secs
vault.read.timeout
The read timeout of the Vault client
15 secs
vault.ssl.enabledCipherSuites
A comma-separated list of the enabled TLS cipher suites
none
vault.ssl.enabledProtocols
A comma-separated list of the enabled TLS protocols
none
vault.ssl.key-store
Path to a keystore. Required if the Vault server is TLS-enabled
none
vault.ssl.key-store-type
Keystore type (JKS, BCFKS or PKCS12). Required if the Vault server is TLS-enabled
none
vault.ssl.key-store-password
Keystore password. Required if the Vault server is TLS-enabled
none
vault.ssl.trust-store
Path to a truststore. Required if the Vault server is TLS-enabled
none
vault.ssl.trust-store-type
Truststore type (JKS, BCFKS or PKCS12). Required if the Vault server is TLS-enabled
none
vault.ssl.trust-store-password
Truststore password. Required if the Vault server is TLS-enabled
none
