HashiCorp Vault providers
Two encryption providers are currently configurable in the bootstrap-hashicorp-vault.conf file:
Provider Provider Identifier Description
HashiCorp Vault Transit provider
hashicorp/vault/kv/{vault.transit.path}
Uses HashiCorp Vault's Transit Secrets Engine to decrypt sensitive properties.
HashiCorp Vault Key/Value provider
hashicorp/vault/kv/{vault.kv.path}
Retrieves sensitive values from Secrets stored in a HashiCorp Vault Key/Value (unversioned) Secrets Engine.
Note that all HashiCorp Vault encryption providers require a running Vault instance in order to decrypt these values at NiFi's startup.
Following are the configuration properties available inside the bootstrap-hashicorp-vault.conf file:
