Automatic diagnostics on restart and shutdown
NiFi supports automatic diagnostics in the event of a shutdown. The feature is disabled by default. The settings can be found in the nifi.properties file and the feature can be enabled there also. In the case of a lengthy diagnostic, NiFi may terminate before the diagnostics are completed. In this case, the graceful.shutdown.seconds property should be set to a higher value in the bootstrap.conf.
