Apache NiFi Registry Admin GuidePDF version
Web Properties
These properties pertain to the web-based User Interface.
Property
Description
nifi.registry.web.war.directory
This is the location of the web war directory. The default value is ./lib.
nifi.registry.web.http.host
The HTTP host. It is blank by default.
nifi.registry.web.http.port
The HTTP port. The default value is 18080.
nifi.registry.web.https.host
The HTTPS host. It is blank by default.
nifi.registry.web.https.port
The HTTPS port. It is blank by default. When configuring NiFi Registry to run securely, this port should be configured.
nifi.registry.web.jetty.working.directory
The location of the Jetty working directory. The default value is ./work/jetty.
nifi.registry.web.jetty.threads
The number of Jetty threads. The default value is 200.
