Using the Apache NiFi ToolkitPDF version
HASHICORP_VAULT_KV
This protection scheme uses https://www.vaultproject.io/docs/secrets/kv/kv-v1 to store sensitive values as Vault Secrets. All HashiCorp Vault configuration is stored in the bootstrap-hashicorp-vault.conf file, as referenced in the bootstrap.conf of a NiFi or NiFi Registry instance. Therefore, when using the HASHICORP_VAULT_KV protection scheme, the nifi(.registry)?.bootstrap.protection.hashicorp.vault.conf property in the bootstrap.conf specified using the -b flag must be available to the Encrypt Configuration Tool.
