File System Content Repository Properties
Property
Description
nifi.content.repository.implementation
The Content Repository implementation. The default value is org.apache.nifi.controller.repository.FileSystemRepository and should only be changed with caution. To store flowfile content in memory instead of on disk (at the risk of data loss in the event of power/machine failure), set this property to org.apache.nifi.controller.repository.VolatileContentRepository.
nifi.content.claim.max.appendable.size
The maximum size for a content claim. The default value is 1 MB.
nifi.content.claim.max.flow.files
The max amount of claims to keep open for writing. The default value is 100
nifi.content.repository.directory.default*
The location of the Content Repository. The default value is ./content_repository. + NOTE: Multiple content repositories can be specified by using the nifi.content.repository.directory. prefix with unique suffixes and separate paths as values. + For example, to provide two additional locations to act as part of the content repository, a user could also specify additional properties with keys of: + nifi.content.repository.directory.content1=/repos/content1 nifi.content.repository.directory.content2=/repos/content2 + Providing three total locations, including nifi.content.repository.directory.default.
nifi.content.repository.archive.max.retention.period
If archiving is enabled (see nifi.content.repository.archive.enabled below), then this property specifies the maximum amount of time to keep the archived data. The default value is 12 hours.
nifi.content.repository.archive.max.usage.percentage
If archiving is enabled (see nifi.content.repository.archive.enabled below), then this property must have a value that indicates the content repository disk usage percentage at which archived data begins to be removed. If the archive is empty and content repository disk usage is above this percentage, then archiving is temporarily disabled. Archiving will resume when disk usage is below this percentage. The default value is 50%.
nifi.content.repository.archive.backpressure.percentage
This property is used to control the content repository disk usage percentage at which backpressure is applied to the processes writing to the content repository. Once this percentage is reached, the content repository will refuse any additional writes. Writes will be refused until the archive delete process has brought the content repository disk usage percentage below nifi.content.repository.archive.max.usage.percentage. The value must be a valid percentage e.g. 60% For example, if nifi.content.repository.archive.max.usage.percentage is 50% and nifi.content.repository.archive.backpressure.percentage is 60%, then if the content repository reaches 60% utilisation of storage capacity, all further writes are blocked until utilisation is brought back down to 50%. When not set, the default value is derived as 2% greater than nifi.content.repository.archive.max.usage.percentage. For example, if nifi.content.repository.archive.max.usage.percentage is 50% and nifi.content.repository.archive.backpressure.percentage is not set, the effective value of nifi.content.repository.archive.backpressure.percentage will be 52%.
To enable content archiving, set this to true and specify a value for the nifi.content.repository.archive.max.usage.percentage property above. Content archiving enables the provenance UI to view or replay content that is no longer in a dataflow queue. By default, archiving is enabled.
nifi.content.repository.always.sync
If set to true, any change to the repository will be synchronized to the disk, meaning that NiFi will ask the operating system not to cache the information. This is very expensive and can significantly reduce NiFi performance. However, if it is false, there could be the potential for data loss if either there is a sudden power loss or the operating system crashes. The default value is false.
nifi.content.viewer.url
The URL for a web-based content viewer if one is available. It is blank by default.
nifi.content.repository.archive.cleanup.frequency
The frequency with which to schedule the content archive clean up task. The default value is 1 Second. A value lower than 1 Second is not allowed.
