escapeJson
JSON Stringifies a Record, Array or simple field (e.g. String), using the UTF-8 character set. For example, given a schema such as:
{ "type": "record", "name": "events", "fields": [{ "name": "person", "type": "record", "fields": [ { "name": "name", "type": "string" }, { "name": "age", "type": "int" } ] }] }
and a record such as:
{ "person": { "name" : "John", "age" : 30 } }
The following record path expression would convert the record into an escaped JSON String:
RecordPath |
Return value |
"{\"person\":{\"name\":\"John\",\"age\":30}}" |
"\"John\"" |
"30" |
