base64Decode
Decodes a Base64-encoded String or byte[]. For example, given a schema such as:
{ "type": "record", "name": "events", "fields": [ { "name": "name", "type": "string" } ] }
and a record such as:
{ "name" : "Sm9obg==" }
The following record path expression would decode the String using Base64:
RecordPath |
Return value |
John |
